Cannot open TeamViewer
zanestein
zanestein Posts: 2
I have Windows 10.  Clicking on the TeamViewer icon will not open the program, but it shows the program running in TaskManager.  I have verified that TeamViewer is running in Services, and also tried restarting it.  I have tried running the program as Administrator.  I have tried redownloading the program.  I have added an exception for TeamViewer to my Avast Antivirus, and to Windows Defender.
Interestingly, I have another icon for TeamViewer: Remote Control, and that works fine.
What can I do to get the program working?
  • Rob-G
    Rob-G Posts: 6
    Have you tried re-installing the software? I would try doing it over the top of your current install first, as there may be a component missing causing the load to fail.
  • zanestein
    zanestein Posts: 2
    I had tried that before I even posted my problem.  Last night, I uninstalled Team Viewer, manually deleted every folder and file I could find labeled Team Viewer, reinstalled.  Still can not open the program.
    I did not as yet try deleting all registry entries before reinstalling, but that may be my next course of action unless somene has an alternative idea.
  • bplives
    bplives Posts: 2 ✭✭
    I found this while also searching for a solution.....
    https://community.teamviewer.com/English/discussion/1616/teamviewer-wont-start
