Multiple NICs
Is it correct, that I have to assignTeamViewer from scratch, when I change NIC (LAN-hardware)?
How does TeamViewer handle multiple NICS?
I have a computer with an onboard-NIC, that seems to be the cause of instability, so I have mounted two extra NIC-cards to backup internet-connection. Will TeamViewer shift to a separate NIC, if the standard-NIC fails? (Network and Sharing Center shows, that all tree connections are connected.)
  • DomLan
    DomLan Posts: 490 ⭐Star⭐
    Hi @MartinLund,
    i think so: the mac address has changed...
    Domenico Langone
    MCSD: App Builder
  • MartinLund
    Thank you for your suggestion .
    Well, if so, it would be nice if you could assign multiple MAC-addresses to the same ID......
    /MartinLund
  • DomLan
    Hi @MartinLund,
    I think that mac address is "part" of ID.
    What you ask may be unworkable. I use the conditional, but I do not think so in this case...
    Domenico Langone
    MCSD: App Builder
