Can not quit from Teamviewer Win (ru)
Quit button is not active...
How to make it active?
Снимок экрана 2019-08-08 в 19.58.01.pngСнимок экрана 2019-08-08 в 19.58.05.png
  • Giovanni
    Giovanni Posts: 49 Staff
    Hi @4vlad ,
    thank you for your message.
    The fact that you cannot close Teamviewer completely is because you activated an option called "Disable TeamViewer shutdown" (Extras-Options-Advanced, section "More")
    Once you disable it you will be able to shutdown TeamViewer.
    Giovanni
Howdy, Stranger!
