access from windows 10 pc to unattended android device
hello @zw ,
Thank you for your post and welcome to the community!
Did you check if your android device is supported? Please read here: Supported manufacturers for remotely controlling Android devices
If yes, do you receive any kind of error message? Could you please post also a screenshot?
Best, Alena
Alena C
Spanish Community Moderator0 -
"a connection could not be established" error on pc
my samsung note 9 is on the list
exactly whats software should i be running on the controlling pc & on the controlled android?
just received the following email:
Hello zw,
Your topic recently received a reply.
Topic: access from windows 10 pc to unattended android device
Date: 14 Aug 2019, 8:02 AMDid it solve your problem?
obviously, problem not solved, u should change the auto reply algorithm...
