QuickSupport: Version out-of-date: Update the remote TeamViewer
Hello Community,
whenever I try connecting to another Computer running the newest custom QuickSupport-Module, it says "Version out-of-date: Update the remote TeamViewer". When I x out that popup, the next message appears: "Unable to connect. Reason unknown."
I hope you can help me.
Best regarts and thanks in advance,
Marco
    JeanK Posts: 3,332 Moderator
    Hello @marco_a_fischer,
    Could you please try to:
    1. Reinstall the latest version of the QuickSupport via the link: TeamViewer QuickSupport
    2. Restart the TeamViewer service on your local computer
    Hint:
    - Execute "run", type "services.msc" and press OK
    - Now find TeamViewer, and restart it by doing a right click.
    Then, restart the TeamViewer application. It should work again.
    Jean Kinzler
    French Community Moderator
  • TyGeek97
    TyGeek97 Posts: 1
    @JeanK
    i am having the same issue.
    when i try to use the download link it is not my custom one and on my end it says i need to buy teamviewer.
    @TyGeek97,
    You seem to get the commercial use suspected message.
    This is something different.
    For this issue, please refer to the following article: TeamViewer thinks I’m using the software commercially!
  • @JeanK, I am having the same problem as @marco_a_fischer. Whenever I try to install quicksupport through a custom module on a remote computer, everything works fine until I try to connect. On the local end I get a notification that I have been assigned a service case, but when I try to connect via a remote confirmation, this message pops up:
    followed by this message
    I am using the latest version of teamviewer (14.5.1691). If you know how to fix this problem, please let me know.
    Thanks,
    Mitch /\rseneau
    This is a very informative blog for me. I am very much benefited after reading this blog. Keep sharing.
  • sarel
    sarel Posts: 1
    this solution does not work
  • itchibahn
    itchibahn Posts: 8 ✭✭
    I have Lifetime License, and has the same issue as @marco_a_fischer and @mitcharseneau. I've search through the community, but seems there's no solution to this problem, yet.
  • ÆGIS
    ÆGIS Posts: 2
    Same problem for us. Was this ever solved by teamviewer ?
  • @ÆGIS No, I wish there was a way to get in direct contact with the support team, but unfortunately we just have to wait until someone solved the issue here.
  • no one was able to solve the problem?
Howdy, Stranger!
