create password for all hosts
Hi community,
I have TeamViewer 14 with corporate affiliation. I  'm trying to install and configure hosts >
When i test and launch a TV host, it give me exclusively an ID but no password.
So when i try to connect as master on this host, with the id it ask me for a password.
When i created the host module to deploy, there is no way to create a password. When i checked for a strategy, the same no way!
Could you help me please.
Thank you.
    Hello @Needhelp,
    You can push the same password for all the Hosts you are deploying. This is possible.
    If you want to do so, please contact our support. They will advise you what you need to do.
    If you want to set up manually passwords on your Hosts, please check out this article here: Password for unattended access
    Sorry for the late reply.
    Cheers,
