yum/rpm repo outdated ?
to me it looks like the yum repo ( configured by a teamviewer 14.1 rpm installation) is outdated.
I had to install 14.2 again manully ( downloading from website).
my environment: openSuse Leap 15.1
installed rpm:
$ rpm -qa | grep teamviewer
teamviewer-suse-14.2.8352-0.x86_64
repo configuration:
$ zypper lr -u | grep teamviewer
17 | teamviewer | TeamViewer - x86_64 | Yes | (r ) Yes | No | http://linux.teamviewer.com/yum/stable/main/binary-x86_64/
manually refreshing:
# zypper -vv ref 17
Verbosity: 3
Non-option program arguments: '17'
Initializing Target
Specified repositories: teamviewer
Checking whether to refresh metadata for TeamViewer - x86_64
Retrieving: http://linux.teamviewer.com/yum/stable/main/binary-x86_64/repodata/repomd.xml .................[done]
Retrieving: http://linux.teamviewer.com/yum/stable/main/binary-x86_64/media.1/media .......................[done]
Repository 'TeamViewer - x86_64' is up to date.
Specified repositories have been refreshed.
seems to be successful.
searching for teamviewer:
$ zypper se -s teamviewer
Loading repository data...
Reading installed packages...
S | Name | Type | Version | Arch | Repository
| teamviewer | package | 14.1.3399-0 | x86_64 | TeamViewer - x86_64
| teamviewer | package | 14.0.14470-0 | x86_64 | TeamViewer - x86_64
| teamviewer | package | 13.2.26559-0 | x86_64 | TeamViewer - x86_64
| teamviewer | package | 13.2.13582-0 | x86_64 | TeamViewer - x86_64
| teamviewer | package | 13.1.8286-0 | x86_64 | TeamViewer - x86_64
| teamviewer-host | package | 14.1.3399-0 | x86_64 | TeamViewer - x86_64
| teamviewer-host | package | 14.0.14470-0 | x86_64 | TeamViewer - x86_64
| teamviewer-host | package | 13.2.26559-0 | x86_64 | TeamViewer - x86_64
| teamviewer-host | package | 13.2.13582-0 | x86_64 | TeamViewer - x86_64
| teamviewer-host | package | 12.1.83885-0 | x86_64 | TeamViewer - x86_64
| teamviewer-host-suse | package | 14.1.3399-0 | x86_64 | TeamViewer - x86_64
| teamviewer-host-suse | package | 14.0.14470-0 | x86_64 | TeamViewer - x86_64
| teamviewer-host-suse | package | 13.2.26559-0 | x86_64 | TeamViewer - x86_64
| teamviewer-host-suse | package | 13.2.13582-0 | x86_64 | TeamViewer - x86_64
i+ | teamviewer-suse | package | 14.2.8352-0 | x86_64 | (System Packages)
v | teamviewer-suse | package | 14.1.3399-0 | x86_64 | TeamViewer - x86_64
v | teamviewer-suse | package | 14.0.14470-0 | x86_64 | TeamViewer - x86_64
v | teamviewer-suse | package | 13.2.26559-0 | x86_64 | TeamViewer - x86_64
v | teamviewer-suse | package | 13.2.13582-0 | x86_64 | TeamViewer - x86_64
v | teamviewer-suse | package | 13.1.8286-0 | x86_64 | TeamViewer - x86_64
does not list version 14.2 rpm available on the remote repo (except the one manually installed) .
Are you not distributing via the Yum repo anymore ?
hi,
for me the Teamviewer yum repo works again since a few days.
zypper on opensuse leap 15.1 can refresh without issue ( GPG checks are enabled ).
Thank you Teamviewer for fixing this issue. now the SW update causes again less effort.
The sad thing is that it took over 3 months the fix this. there was no reaction from Teamviewer on this issue on this forum. I see room for improvement.
5
it looks as if someone at Teamviewer has changed the repo contents without signing the repomd.xml correctly, therefore the integrity check fails:
File repomd.xml from repository TeamViewer - x86_64 │
│ http://linux.teamviewer.com/yum/stable/main/binary-x86_64/ │
│ is signed with the following GnuPG key, but the integrity check failed: │
│ ID: C5E224500C1289C0 │
│ Fingerprint: 8CAE 012E BFAC 38B1 7A93 7CD8 C5E2 2450 0C12 89C0 │
│ Name: TeamViewer GmbH (TeamViewer Linux 2017) <support@teamviewer.com> │
│ Created: 03/13/17 │
│ Expires: Never@TeamViewer: please fix the repo signature
hi,
5
