Is there any Teamviewer API available for remote control required for integration?
testerdavi
Posts: 6 ✭✭
Need an Api for team viewer remote control for integration (as available for remote session) , is there any documentation available.
Davi
Hi @testerdavi
Yes, TeamViewer does have API available. Feel free to browse Is there a TeamViewer API? for more information. If you would like to have individual assistance on TeamViewer API, kindly contact TeamViewer Support Team.
Hope you find the information is helpful.
Community Moderator/中文社区管理员0 -
hi @Ying_Q
Thank you for your answer, i checked the url.
I need an specific API for unattended Remote control
Is it possible to create an unattended remote control session with the host computer, by an api call , if the remote id and password of the host is known.
Davi
