Teamviewer Host on Raspberry
VNMurthy
in Linux only
I have an Raspberry Pi 3 with Raspbian OS and installed Teamviewer Host application for unattended access. Due to recent cyberattackes, our netproviders blocked some ports (Port: 443). After that I am unable to access that device. If it uses Port:443, is it possible to change the Port from 443 to 80 or 8080, so that I can access.
Hi VNMurthy,
usually, TeamViewer detects connection problems and tries other ports. You can try to enforce using Port 80 like this:
teamviewer daemon stop
echo '[int32] ConnectionProtocol = 3' >> /opt/teamviewer/config/global.conf
teamviewer daemon startGood luck :smileyhappy:
Linux Developer1
