Cross copy/paste between 2 connected computers
DJ27
DJ27 Posts: 1
Consider the below scenario,
Two computers (Say X & Y) connected to one remote computer (say Z). "X" is actively working on "Z" and copies some conent. "Y" is just connected to remote computer, but not doing anything in it. If "Y" tries to paste something for his work locally on his computer, then whatever content "X" has been copied is being pasted to "Y" computer.
Is there  solution to avoid this cross copy & paste?
Thanks,
DJ
  • Ying_Q
    Ying_Q Posts: 2,584 Moderator
    Hi @DJ27,
    Kindly check on the setting on device Y - TeamViewer -> Extras -> Options -> Advance -> Advanced connection settings to other computers -> Clipboard synchronisation -> untick the setting.
    Hope the information above will be helpful.
    Community Moderator/中文社区管理员
