Teamviewer Quick Support Incompatible
I keep trying to access iphone/ipad from my computer using teamviewer to connect to teamviewer quicksupport but the quicksupport says teamviewer versions are incompatible. Please help
  • Esther
    Hi @Simpolwon
    Can you tell us, which versions you are using on your devices?
    Please make sure, that you are using the latest version on your computer and your iPhone/iPad.
    Thank you, Esther
  • Hi
    I have same problem using v13.0.281 on chromebook and v13.0.7847 QS on android , both installs are the latest version. I also get message "Unfortunately a connection to this device is not possible with this version of Teamviewer"  on the chromebook.
  • I am having the same problem with my Ipad and Linux as well.
    Hello @webiflex,
    We are happy to announce that you can now share the screen of your devices running ChromeOS. ?
    If you want to connect via unattended access, please use the TeamViewer Host.
    If you want to connect spontaneously, please use the TeamViewer QuickSupport.
    You will find the download links here:
    Alternatively, you can also download these versions directly on our website here: TeamViewer for Chrome OS
    Please also find additional information here: Supported platforms - Chrome OS
