Samsung Galaxy Tab S5e Quicksupport rotated screen
Hi!
On my Samsung Galaxy Tab S5e (Model nr.: SM-T725)
There is some issues with Teamviewer 15 Quicksupport,
as it is twisting the screen sideways, with the wrong aspect ratio(See attached images)
I am running Teamviewer Quicksupport v. 15.1.24 QS (UDP enabled)
My PC client(Win 10) is v. 15.1.3937
Sideways screenSideways screenTablet infoTablet infoAndroid infoAndroid info
  • johnsk
    johnsk Posts: 2
    I have the same problem. I don't know of any remedy.
  • Alexbits
    Alexbits Posts: 2 ✭✭
    Same here. How hard is to fix this!?
  • same problem here. it worked on an old ASUS tablet.
    do you have the WIFI only version of the S5e?
    I use a version with 4G support.
  • johnsk
    johnsk Posts: 2
    Hi @PeterAckermans
    It's the 4G model here. The tablet belongs to my mother and I haven't revently tested whether the problem persists. I take it from you that it does. I had hoped for an update to the Android application that would remedy it.
    Too bad.
  • Can't believe this issue was reported in January and it's still unresolved in late April!
    I'm seeing the same in two Samsung Galaxy Tab S5e tablets (WiFi only model)
    Model: SM-T720
    Android v9
    Team Viewer Host 15.4.33 HM
