webapi.teamviewer.com/api/v1/oauth2/authorize return 404 - File or directory not found.
We have been using the API without any issues for some time.
Today I checked and got error 404 for this API:
Any idea why? Did the API change? Does it work for you?
For OAuth2 you need to use the URL
https://login.teamviewer.com/oauth2/authorize?
This is not an API call, but a plain redirect for passing control to TeamViewer to auth the user. webapi.teamviewer.com/api/v1/ is for API calls.
Please review chapter 3 from the Web API specs at https://dl.teamviewer.com/integrate/TeamViewer_API_Documentation.pdf
6
I'm having the same problem. Need to fix it urgently!
Getting same problem and it was working before 2-3 weeks.
6 -
I'm having trouble receiving a token with TeamViewer API:
I am using Postman to make my requests here is my configuration
Callback URL: https://oauth.pstmn.io/v1/callback
Auth URL: https://login.teamviewer.com/oauth2/authorize
Access Token URL: https://webapi.teamviewer.com/api/v1/oauth2/token
The End Result is as follows:
Is there anything that I didn't configure properly?
