your current TeamViewer plan does not include connections to customized TeamViewer modules.
I just installed TeamViewer to remote access my other PC for personal use. What is this error that keeps popping up every time I try to connect and why am I getting it?
How do I get rid of it? I don't think I'm using anything "custom".
  • simondoetsch
    does anyone has a solution for that?
  • mrshnatter
    Really? The first (actuallty only?)  item in the search results, it's over a year old, 20 others have this question and no one posted an answer?  There's other products out there that does what TV does.  And maybe the support would be better.
