Testing ID 12345 is it no more available?
I installed TeamViewer 12 on my Linux system, it seems to run regularly, but I didn't try any real remote control. I saw a video tutorial in which the operator shows it is possible to simulate a remote control by inserting the target ID "12345". In that video a new window with the remote system appears and as I well understand it should be a real remote machine provided by teamviewer to let users test their installed software.
I tried to insert "12345" as remote ID, but it returns that ID is unknown.
So I asked if that testing remote ID is still available or not, and if it was really available in the past.
Thanks in advance!  :)
  • ChristianCay
    Hi joeviewer,
    The test ID 12345 is not available anymore. That's the reason why you're getting that message. If you need to test TeamViewer on your system, we recommend you to install TeamViewer on another device and connect to that one.
    Christian
  • A test ID would be very usefull! I use TViewer on a Linux-System (18.04) an I have problems. TViewer stops immediately. Therefore it would be very usefull to have a test-ID to determine where the problem is. (PC, Router, I-net-connection, remote-PC, ...)
  • NOW I need a TEST ID just to SEE if it works
    maybe We can both comunicate
    Now 10 November 2020
    I have the ID :
    **Please do not post TeamViewer IDs**
    password **Please do not post TeamViewer IDs**
    my phone number is
    +**Please do not post TeamViewer IDs**3
    send me on WatsUP a messaje for test
    or on fb messenger : oradeaoradea2003
    thanks
