Installing Team Viewer on corporate laptop to access my home computer
tmp
tmp Posts: 1
Hi there,
I was thinking about installing team viewer on the machine I got from my work, so that I can from time to time log in to my home machine when I want to do something on it while at work. I consider this being a personal use case, but I am not sure if it is the correct interpretation. I would be glad to find that out and be sure before I install it. What do you think?
  • any news?
  • Esther
    Hi @Tokukarin
    Thanks for your question.
    What you are describing is indeed a typical use case for commercial usage as it is a connection from your work computer.
    The other way around: From your home computer to your work computer is also commercial. Basically every connection you make from or to your work computer requires a license.
    If this is the only connection you want to make, I recommend the new Remote Acces license for you. I´ll get you the link for more information: https://www.teamviewer.com/en/content/lo-remote-access/
    I hope this clarifies your question.
    Best, Esther
  • bupviewer
    bupviewer Posts: 1
    edited December 2023
    this is from TeamViewer website:
    Example of direct payment:
    • a customer pays you for providing support
    Examples of indirect payments:
    • a software company sells a software product for which it offers free support via TeamViewer
    • teamwork among colleagues within a company
    • use in associations and non-profit organizations
    • access to a company computer for work-related activities
    In the above-mentioned cases for indirect payment, TeamViewer is used for creating an added value, the payment takes place indirectly through salaries or a combination of sales/support activities.
    So how exactly is the current case a "typical use case for commercial usage as it is a connection from your work computer."? Note the fouerth line in the indirect payments example: "access to a company computer for work-related activities"
    He is using Teamviewer to work on his personal projects in his home PC. So it does not seem to me like a commercial use case at all.
    So please TeamViewer, explain.
