Be able to mute incoming sound from remote computer
it will be a nice feature to be able to mute the incoming sound of a remote computer. I find it very anoying specially if the other user is listening to music or if we are talking to each other via other means such as Teams. At least I was not able to find it how.
Carlos Cavia
Hi @caviapc
I would recommend you to give a look at this post. In your case just un-click the sound boxes!
Please don't forget to update if this worked for you.
Best regards
