Connection with Telephone host
Hi @Wojtii
Did you see a message to install an add-on to the phone? If yes did you installed it? It could be needed to start the installation procedure from again.
Also, please try to disable the screen autorotate in landscape mode for a moment to see if this changes anything.
I hope this helps you to solve it.
Best regards
