Teamviewer quits everytime I connect to a machine
I am using version 12.0.78517 on a Mac running OS X 10.12.4 and every time I connect to any computer, Teamviewer quits. I already uninstalled (including configuration) and reinstalled, but that made no difference.
  • bartlanz
    bartlanz Posts: 315 ✭✭✭
    Does the whole program close out on you or just the remote control window? I've been having an issue occasionally when I log into a PC I get kicked out of the session imediatly, but once I log back in I'm good to go.
    Bart Lanzillotti
  • mauricev
    mauricev Posts: 3
    The whole program appears to vanish and then relaunch. It's 100% reproducible. I can't log into any other machine from the afflicted machine.
  • bartlanz
    Huh, that's a weird one. Unfortunately I don't have a Mac at my disposal to play with. If you are a paid user, I would try contacting support and see if they can help you out.
    Bart Lanzillotti
  • mauricev
    mauricev Posts: 3
    That worked. The current version of Teamviewer on the Mac is broken.
