Teamviever Host + easy access
I am trying to deploy TeamViewer Host to new computers in my org. I have the following set and it installs the customized teamviewer host but does not assign easy access. Obviously some data has been changed/removed.
/qn CUSTOMCONFIGID=123abcd APITOKEN=[REMOVED] ASSIGNMENTOPTIONS="--grant-easy-access" ALLUSERS=1
It is clearly taking the CUSTOMCONFIGID but is not taking the Assignment options (I don't know how to tell if it is taking the APITOKEN.
    Hello @nsumner,
    Thank you for your message and welcome in the TeamViewer Community! ?
    So to understand better the situation...
    When you run the command, it installs a TeamViewer Host, without any customization and also does not apply the parameters? Or can you see the customization?
