Always have to grant permissions in accessibility options on Mojave 10.14.6?
Trying to use TeamViewer on MacOS Mojave 10.14.6 but every time I restart my Mac and connect again I have to repeatedly grant permissions for keyboard and mouse control in accessibilty options? This should stay granted forever, obviously; I don't want to end up halfway around the globe and unable to connect to my home computer because it forgot some setting that I have to enable locally. Anyone know how to fix this?
  • Vatsilidis
    Vatsilidis Posts: 655 ⭐Star⭐
    Hi @peanutismint
    I'm not quite sure since Mojave is a bit old OS, but have you tried to enable in the Advanced menu the option to be fully controlled remotely the mac, during a remote connection?
    please look at the screenshot where is this option is.
    I hope this solves your issue.
    Best regards
  • peanutismint
    Thanks, I hadn't seen that setting but sometimes trying to log into this Mac takes me to the login screen (even though I don't have the login screen or any kind of password protection enabled on my home computer) so this might actually be what was blocking my path. I'll respond if it doesn't work :-)
