Forward special keys using remote desktop inside a teamviewer session doesn't work
cosmos321
cosmos321 Posts: 2 ✭✭
i've encountered an issue of forwarding special keys while using remote desktop inside a teamviewer session. The same problem is described here: CLICK
I use the latest version 14.4.2669 (on both sides). Host and guest are running windows 10. Due to this bug I am not even able to log in to the RDP session., because my password also consists of capital letters.
Inside the teamviewer-session, everything's alright. The checkbox “Send key combinations” ist activated und Copy/Paste (ctrl) inside the teamviewer-session is possible. Also capital letters (shift). But in the RDP-session "shift" and "ctrl" doesn't get forwarded.
Any suggestions how to solve the problem?
Kind regards,
cosmos321
  • CHCSean
    CHCSean Posts: 1
    edited March 2022
    Same here. TV into work pc, then RDP into server..., shift and CTRL do not pass through to RDP session.
    **bleep** when you have a ! in your password.
  • manni71
    manni71 Posts: 1
    It is the same with Linux hosts as well.
    If I connect with TV from Windows 10 PC to Linux hsot and RDP to another hsot the  keyboard is "broken". Seems to be a wrong mapping.
  • EJD
    EJD Posts: 1
    I’m having the same issue along with not send the shift keys but also ctrl so no copy paste with keyboard. Any chance anyone else is also using a Corsair keyboard?
  • oba
    oba Posts: 4 ✭✭
    Dont run RDP session in full screen then you can send special keys. Its very annoying.
