Cannot reset PC password
Hi, I am trying to reset my PC remote connection password - each time I click on Create New Random Password nothing happens,
I've tried logging out and logging back in, what else should i try?
    Hello @JumboJim,
    Thank you for your message. ?
    I recommend you to uninstall fully the program and try again.
    This should fix the issue.
    If this does not work, you can also deactivate the random password and set up a password for unattended access (a fixed password that won't change).
    We explain how to proceed in this Knowledge Base article right here: Password for unattended access
    I hope this could help. ?
    Best regards
