How do Set Team Viewer Screen fit to my screen?
Here is my team viewer screen,
How to set a full screen?
    Hello @Gta,
    I recommend you to try the three scaling buttons on the left side of the View panel and find out which one fits the best on your local screen:
    I hope this could help. ?
    Best regards
  • Gta
    Gta Posts: 2
    @JeanK Yes, i tried that but no use, still the same size. Is any setting change from end-user Teamviewer settings.
    @JeanK wrote:
    Hello @Gta,
    Best regards
