The password you have entered is invalid, please try again
Bazsl
Bazsl Posts: 10 ✭✭
When I click on one computer under My Computers I get the error dialog in the subject line. If I enter the password the connection is established. This only happens on one computer. What must I do to fix this? Thanks.
    Hello @Bazsl,
    I suggest you to delete the computer from the list and add it back again.
    This might fix the issue.
    I hope this could help. ?
    Best regards
  • Bazsl
    Bazsl Posts: 10 ✭✭
    Sorry but I am a TeamViewer novice. Where should I delete the computer? On the Web site? If so, how? I tried to find a way to delete the computer on the Web site and could not find a Delete option. Thanks for your help.
    Hello @Bazsl,
    I mean deleting the computer from your Computers and Contacts list.
    I made this little GIF to show you:
    Let me know how it goes. ?
    Best regards
  • Wahaj
    Wahaj Posts: 1
    The solution showed above is not helpful. Please tell me the other solution for this invalid password address
  • EnriMoizo
    EnriMoizo Posts: 2 ✭✭
    Same problem here, i'm 500km away and after 5 days, today the password of my remote pc looks changed.... it says Password invalid, i tried with chrome web app too, it refuses the password i was using in these days... i need to connect to my office PC and i can't ... GG Teamviewer
  • KMNug53
    KMNug53 Posts: 7 ✭✭
    Hi Jean K,
    I just wanted to let you know that your suggestion of deleting and re-adding the computer worked for me.
    Thank you,
    -Kevin N.
