How to insert two mouses at the same time?
Hello, people.
It's my first time writing here on this community. I'm a teacher and, in this situation of COVID-19, I'm taking classes on TeamViewer. But the dynamics on the internet and the real life are different.
For that reason, I would like to insert two mouses: one for my student to use the computer and another for me to point and give instructions in class.
Is this possible at all?
  • Vatsilidis
    Vatsilidis Posts: 655 ⭐Star⭐
    Hi @brendo_95
    As far as I know, Windows support one cursor on the screen which you can use it by two mouses.
    Another case it could be to using a touch monitor by you and leave the mouse the student.
    I hope this helps you.
    Best regards
  • brendo_95
    brendo_95 Posts: 2
    Hello, Vatsilidis.
    Thanks for the response. But I don't have a touch monitor. However, I found an option that can help: It's possible to block the student cursor while texting and guiding him.
    I could, also, find another option that can allow two mouses, but both can manage the computer simultaneously.
    ASAP, I can post here.
