Error: CheckCPU: unknown architecture 'aarch64'
I am trying to use TeamViewer on NVIDIA Jetson Xavier (ARM 64 bit ). When I first time install the teamviewer, everything works fine. But when I reboot, the teamviewer daemon crashes every time I open it. Running teamviewer from terminal shows error:
$ teamviewer
Init...
  • mircea_c
    Hi @xhuvom
    You are trying to run on the device "TeamViewer Host Module" or "TeamViewer IoT agent"?
    Mircea
    Tech Support IoT
  • xhuvom
    xhuvom Posts: 3
    Hi @mircea_c
    I am using TeamViewer Host for Raspberry Pi on NVIDIA Jetson Xavier
  • mircea_c
    Hi @xhuvom
    For now, we do not have an aarch64 version of the TeamViewer Host.
    Could you have a look at the steps from here ? I cannot guarantee you that will work!
    Mircea
    Tech Support IoT
