TeamViewer remote screen freeze's after logging out on the remote pc
iainwels
iainwels Posts: 121 ✭✭
I use my teamviewer for work and have to connect to 20 computers every day. But every time i log out on the remote pc it freeze's when it says logging off, and then when i try restarting the teamviewer connection i see a black screen. My colleagues don't have this issue but whenever i get it and they try to connect to that computer they get a black screen also.
Is there an solution out there for this problem?
I use teamviewer 10
With kind regards,
Iain Wels
Iain Wels,
ICT-Support
  • bartlanz
    bartlanz Posts: 315 ✭✭✭
    First off, as a paying customer, I certainly recommend contacting TeamVIewer Support. They will be able to troubleshoot this and help you faster than I can I suspect.
    Second, Let me make sure I understand what you are saying. You have multiple computers that you log into daily. When you log out of windows the remote systems screen locks up and your TeamViewer screen goes black?
    Bart Lanzillotti
  • iainwels
    Yes that is kind of the problem i will show you what the problem is down below!Translation: On the other screen is now just the lockscreenTranslation: On the other screen is now just the lockscreenTranslation: This is what i see when i reconnectTranslation: This is what i see when i reconnectTranslation: I can only reconnect when the other computer has logged in againTranslation: I can only reconnect when the other computer has logged in again
    With kind regards,
    Iain Wels
    Iain Wels,
    ICT-Support
  • bartlanz
    Ahhh, this could be the issue that a user must be logged in for the system to allow connections, TeamViewer released an update today that if that is the issue, it will be fixed. Can you try updating both your client and host machines?
    Bart Lanzillotti
  • iainwels
    Thats a problem because my boss does not want to upgrade from teamviewer 10 because all of our costumers have Teamviewer 10 and my colleagues do not have this problem. Is there not any way around or something?
    Iain Wels,
    ICT-Support
  • bartlanz
    First thing I would point out is that if you upgrade to TeamViewer 12 your customers do not need to upgrade. They just will not be able to connect to your systems. But TeamViewer 12 will connect to earlier versions of TeamViewer.
    As for your connection issue... It is odd that it only happens for you. I would wonder if you have a setting that is different from the rest of your co-workers. I am going to think on this a little bit.
    Bart Lanzillotti
  • iainwels
    If we want to upgrade it is very expensive this is for one computer
    With kind regards,
    Iain Wels ICT-Support
    Iain Wels,
    ICT-Support
  • Reyhan
    Dear @iainwels
    Thank you for your contribution. If you have any questions for update or price information, please contact our salesteam here
    Our Salesteam would be pleased to help you.
    Thank you.
    Reyhan
