How to set Ctrl-Alt-Del in tool bar?
Most of our users run Windows servers, so in order to support their request, the first thing to do *each* time is "Press Ctrl-Alt-Del" in order to log in.
How do I get this action right into the toolbar in order to make this a *single* click action?
I know where to find it. I want it to be a single click action every time, i.e. for every system.
I know, that it can be done, since on some system, where I connect to, there is this ctrl-alt-del in the top level on the tool bar.
Forget this, accidentally found it to be already there as the "running man" icon.
Thx
5
Thx
5 -
My Send Key Combinations check box is checked but the Send Ctrl+Alt+Del with the running man is not active and will not send Ctrl+Alt+Del. What would cause the Send Ctrl+Alt+Del to be displayed but not activated?
3 -
I have same issue - can't get into the remote system because the running man icon is greyed out
1
