TeamViewer Remote is available for the operating systems listed below. You can download the current version of TeamViewer Remote from our website.
Links to older versions can be found in our Knowledge Hub.
The system requirements set out below apply to the following products for remote access & support: TeamViewer Remote and TeamViewer Tensor.
For the use of specific features Monitoring & Asset Management, Endpoint Protection, and Backup, the system requirements Supported operating systems for Remote Management shall apply in addition.
This article applies to all TeamViewer users.
💡Hint: Using older versions of TeamViewer requires a TeamViewer license. We kindly ask all free users to use the latest version of TeamViewer Remote.
Windows
Client versions * Server versions ** TeamViewer versions
Windows 7
Server 2008 R2
TeamViewer 15.41 –15.x
Windows 8.0
Server 2012
Windows 8.1
Server 2012 R2
Windows 10 October 2022 Update (22H2)
Server 2016
Server 2019
Server 2022
Windows 11 (22H2)
Windows 11 (23H2)
TeamViewer 15.47 –15.x
¹ Includes support for Windows 10 IoT Enterprise editions. However, Windows 10 IoT Core and Windows Embedded systems are not supported.
² Windows Server Core installations are not supported.
macOS
Mac versions TeamViewer versions
macOS 10.15 (Catalina)
TeamViewer 15.41.7–15.47
macOS 11.0 (Big Sur)
TeamViewer 15.41.7–15.x
macOS 12.0 (Monterey)
macOS 13.0 (Ventura)
macOS 14.0 (Sonoma)
TeamViewer 15.47-15.x
📌Notes:
  • Currently, there is no possibility to enable "Lock Computer" remotely on macOS Big Sur. This button is, therefore, disabled when connected to a Mac running Big Sur.
  • TeamViewer supports both Apple Silicon and Intel Macs (Apple Silicon is supported in TeamViewer 15.41.7 and newer).
