Frontline Creator allows users to easily configure 2D augmented reality applications - without programming knowledge. For more information see the "
It is a platform tool that allows you to create workflow models of real-world processes. The created workflow is then assigned to a smartglass user for execution. However, often these workflows need to be customized as per the requirements.
Therefore, as a Creator Developer, you will be able to create new or configure existing components of a workflow.
In this training, you will learn how to create your own logic and user interfaces by customizing components.
Prerequisites for training:
1. Access to Frontline Creator: You must have access to a server instance with a user that has a Creator and Developer role.
For more information please see the "section.
2. Smart Glasses with Frontline Workplace: You must have one of the Smartglass supported by Frontline and install the Frontline Workplace application to it.
For more information please see the " section.
3. Access to Frontline Workplace: You must have access to Frontline Workplace with a user that has a Creator and Developer role.
4. Introduction to Frontline Creator: You must have a quick look into the User Manual for Frontline Creator as you would be working mainly on this platform tool.
5. Introduction to Frontline Workplace: You must download and go through the Frontline Workplace quick start guide to learn how to navigate through Frontline Workplace.
