Announcements
This board is exclusively meant for questions about the Community platform.
If you have a question about TeamViewer, Remote Management, Blizz or TeamViewer IoT please post in the support boards for these products.
Thank you!
Posted by bjblackmore
Digon
Difficulties with the forum - links and option menu
Dunno if anyone else if having difficulties with the forum? I'm unable to post links, or click on the 3 little dots in the corner of my posts to edit the post/show options?
1 Accepted Solution
Accepted Solutions
Posted by Community Manager
Solution
Re: Difficulties with the forum - links and option menu
OFF TOPIC REPLY @mLipok: We changed a setting and can you now edit your posts?
Posted by mLipok
Heptagon
Yes. This is true.
Temporary try to post URL Link as a "Code" I mean  </>  button on editor toolbar.
mLipok , AutoIt MVP
Hi bjblackmore,
to post a link, just click in the message editor on the link- icon and hide the link behind a word:
 It looks like this:
  And so it will be shown like this link to the TeamViewer homepage.
Regarding the 3 dots on top: What happens, when you click on the 3 dots?
Thank you and I hope, this answer is helpful.
Digon
I'm not even getting the editor toolbar! I just get Rich text, HTML and Preview. However clicking on any of them clears what I've written in the text box! Try these: h.t.t.p:// 4sysops dot com /archives/get-adcomputer-display-computers-in-ou-or-ad-group-with-powershell/ or: w.w.w powershelladmin dot com /wiki/Getting_computer_names_from_AD_using_Powershell Script: Import-Module ActiveDirectory Get-ADComputer -Filter * | Select -Expand Name | Export-Csv c:\AdExport.txt
Posted by mLipok
Heptagon
TEST URL
 we get "Correct the highlighted errors and try again." and the link dissapers, only text is still in the same places.
mLipok , AutoIt MVP
Digon
Hi Ester, I don't even see the editor tool bar, all I get is the message box with Rich Text, HTML and Preview (clicking on either of these clears what I've written in the message box. If I try to post a link I get an error:  photo TeamViewerForumError.jpgClicking on the 3 little dots in the top right hand corner of a post just jumps the browser up to the top of the page. no menu is shown.
Can you give it a try and click on "Rich Text" instead of "HTML"?
Do you have the options there?
Posted by mLipok
Heptagon
Test
mLipok , AutoIt MVP
Posted by mLipok
Heptagon
TEST 2
btw. To the MOD: I still sometimes can't edit post (this happend again with the above post
mLipok , AutoIt MVP
Posted by mLipok
Heptagon
As far as I remember I was using RichText all the time .
Now it seams all is ok.
mLipok , AutoIt MVP
Seems to work :-)
@bjblackmore can you confirm?
mLipok: The edit-issue is under review ... I will keep you updated
Posted by mLipok
Heptagon
OFF TOPIC REMARK: The edit feature is very important for me as my english is not well, and I still often use GoogleTranslator , and very often want to edit to fix some typos or wording.
mLipok , AutoIt MVP
Solution
Posted by mLipok
Heptagon
Yes now I can.
Thanks.
mLipok , AutoIt MVP
Digon
@Esther
It seems to be working better now. Although for the past hour or 2 I haven't been able to login, to reply. Whenever I tired, it was just going around in circles.
I can post links & upload pictures now, and I can see the editor tool bar buttons above the text box.
And the 3 little dots in the top right of a post now give me a menu, allowing me to edit posts and other options.
Test
Was getting very frustrating for a while there, as I couldn't login to reply or alert anyone!
