Cannot Access Wake on LAN via Public Address and it work via TeamViewer ID
Hi, all I have some issue on setting up the Wake On LAN in Teamviewer.
First of all, I have set up the TeamViewer and all the required things following the Teamviewer Manual and the tutorial in other places. The Wake-on-LAN via a TeamViewer ID in the network is working fine, and it can wake up the targeted computer in “Sleep” and “ShutDown” mode. But I need the Wake-on-LAN work via a public address.
Following is the device I use for Wake-on-LAN:
  1. Asus RT-AC88U router
  2. HP Z420 Workstation as targeted computer
  3. Network card support Wake-on-LAN feature
Following is the router setup for the port forwarding for Wake-on-LAN TeamViewer Capture.PNG
Can someone guide me on how to set it up for the router port forwarding? Thanks
  • Can anyone help me setting the router port forwarding?
    For my case, I need to make the Wake-on-LAN using Public Address to wake up more than 18 targeted computer. So please help me if anyone has the solutions. Thanks!!Capture.PNG
