Announcements
The Community is moving next week!
Find all information incl. the timeline and tips for a smooth migration here.
We will be in read-only mode from this Sunday to Tuesday.
Posted by
Henagon
Connection could not be established, Reason Unknown
I have been trying to access my computer remotely, but I keep getting "a Connection could not be established, Reason Unknown"
Both computers have the same version, so I tried to use a spare computer, the issue still persisted.
Is there any solution to the problem?
Posted by Moderator Moderator
Moderator
Re: Connection could not be established, Reason Unknown
Hi @Yoyo2 ,
Could you please check if you are using the latest version of TeamViewer?
This might help this situation.
Yuri
Japanese Community Moderator
Posted by
Henagon
I updated the version of the computer and the issue is still the same.  It orginally was connecting well and suddenly the issue happened.
Moderator
Hi @Yoyo2 ,
Thank you for your reply.
In this situation, it is difficult to find the exact reason without a logfile.
However, you might be able to do the following checks:
Your general setup
  • Is your Internet connection working?
Did anything change on your IT setup
  • Can TeamViewer reach the Internet?
    • If not, please open Port 5938 for outgoing connections
Did TeamViewer work just a few minutes ago
  • Did you check our Status page
    • Here we post updates about the current TeamViewer system status
Operating system
Hope this will be helpful.
Yuri
Posted by
Henagon
I'm getting the same "reason unknow" message when I try to connect to my laptop from my iPad and the connection fails.  this just started happening in the last week.  Here is a TV suggestion to someone else having the same problem.   Can you tell me how to check and open the Port?
Posted by
Photon
Same problem here. Say needs to update but after give me same error. No ideea why. I use it maybe once a month the free version.
Posted by
Electron
I am aslo facing the same problem. Can you please tell me how to resolve this,
