Announcements
Here you will find the download links for all modules
in version 9: TeamViewer 9
Posted by JellyAhHa
Henagon
Could having both 'TeamViewer' and 'TeamViewer QuickSupport' installed lead to conflicts?
I work for a distributor of Vectorworks providing tech support for users. One of our clients has also purchased a plugin to Vectorworks, called Interior XS which installs with a (branded/customised) copy of 'TeamViewer QuickSupport.'
This client is a big corporate with an IT administered network. They already have TeamViewer installed on every computer and they need to know whether having both of these installed could cause a conflict.
They have also asked for instructions from us on how to remove it. - We are not the manufacturer of this plugin so do not know how to do this and I doubt the manufacture could answer this easily/quickly, - and our client expects/needs an answer quickly.
Can someone with the ability to answer this definitively please help?
1 Accepted Solution
Accepted Solutions
Posted by Senior Moderator Senior Moderator
Senior Moderator
Solution
Re: Could having both 'TeamViewer' and 'TeamViewer QuickSupport' installed lead to conflicts?
Hi JellyAhHa
Thanks for posting!
The only conflict this could cause is that only one will be able to run at a time. Any attempts to have 2 running at the same time will show "There is already an instance of TeamViewer running".
It is important to note that QuickSupport is not an installable product, it is run only. So essentially, if you have TeamVeer (Host or full version) running all the time, the QuickSupport part of the plugin will simply not be able to run (As there is already an instance running).
So if you install TeamViewer, the Quicksupport will not interfere with it as it will not run.
I hope this answers your question
-Scotty
Senior Moderator
View solution in original post
Senior Moderator
Solution
Hi JellyAhHa
Thanks for posting!
-Scotty
Senior Moderator
Posted by JellyAhHa
Henagon
Thank you Scotty!
I believe that does resolve the query, thank you. I did want to also find out how the 'QuickSupport' one could be removed, but because the full TeamViewer and the TeamViewer QuickSupport can't run simultaneously, AND because there would be very little likelihood that a user would find and/or need to launch the 'QuickSupport' application directly, I expect there is no need to exclude or remove it from the installation, so this question might now be moot. If you have any further comment on this matter, please let me know. Otherwise, I'll leave it at that.
Cheers!
Jeremy
Senior Moderator
Hi JellyAhHa,
Sorry, I honestly have no idea how to remove our software from their plugin. Generally, they package the QS exe inside their package somewhere and simply add a link in their software directing to this.
So it may be possible to delete the exe or it may not be removable, I can't say.
All I can say is that your installed version will stop their QS from working, but the QS will not interfere with your clients TeamViewer.
-Scotty
Senior Moderator
