Customized Teamviewer 14 host mass deploy - Assigned PC not show up in teamviewer console
Announcements
Remote Control for all devices running Android 7+ is here!
(Incl. Google Pixel series, Xiaomi smartphones, Oppo devices, and many more)
Learn more
Highlighted
Posted by
Photon
Problem: PC does not show up in teamview console  -> groups
The host running on client PC "Options" -> "General" -> "Account assignment" shows "Assigned to XXXXX" which XXXXX is corp. account name.
PC ran deployment script yesterday appears in groups correctly except those ran the script today and there do not seems to have obvious reason.
Hope someone can help point me in correct direction to fix this and make it work all the time
Install string:
msiexec.exe /i "TeamViewer_Host.msi" /qn APITOKEN=myTokenNum CUSTOMCONFIGID=myID IMPORTREGFILE=1 ASSIGNMENTOPTIONS="--grant-easy-access --group ""A B"""
reg file was exported from tech PC and named TeamViewer_Settings.reg as mentioned in deployment doc (https://community.teamviewer.com/t5/Knowledge-Base/Mass-deployment-improvements/ta-p/39639#toc-hId-*...
1 Reply
1 Reply
Highlighted
Posted by
Photon
Re: Customized Teamviewer 14 host mass deploy - Assigned PC not show up in teamviewer console
trialed with remaining attributes and adding --reassign in existing string fix the problem
Just incase someone is having same issue
