Posted by Bazsl
Henagon
How to connect to headless computer across LAN?
I want to connect to a headless PC across my LAN using TV. The problem is that there is no way to get the password from the machine I am connecting to. Is there solution? Thanks.
1 Reply
1 Reply
Posted by IvanT
Henagon
Re: How to connect to headless computer across LAN?
Try to set a defined password to get access with this password instead of generated one. To define the password go Extras->Options->Security. Type your password and confirm. Might this help.
