I bought a Business Licences, do i need to activate it on every machine I am going to connect to ?
Highlighted
Posted by
Photon
Hello and Thanks in advanced. I Bought a bussiness Liences for me, I am planning on connecting to a bunch of users as needed. My question is do I need to sign in to team viewer on there machine to activate the Liecnse or does only my machine need to liencse ?
Thanks.
1 Reply
1 Accepted Solution
Accepted Solutions
Highlighted
Posted by Senior Moderator Senior Moderator
Senior Moderator
Solution
Re: I bought a Business Licences, do i need to activate it on every machine I am going to connect to ?
Hello @csaunders34,
With TeamViewer, only one side of the connection needs to have the license. Therefore, you need only license your own devices, that you will use to connect to your users.
For more information on licensing devices with the Business License, please see here.
Hope this helps!
Josh P.
Senior Moderator
If my reply answered your question, help out other users and click the Accept as a Solution  button below.
You can also say thanks by clicking on the Thumbs Up button!
Thanks for being an active member of our Community!
Japanese Community (日本語コミュニティ) |  Chinese Community (中文社区) |  German Community (Deutschsprachig) | French Community (Communauté française) | English Community | Spanish Community (Comunidad española)
View solution in original post
1 Reply
Highlighted
Senior Moderator
Solution
Hello @csaunders34,
Hope this helps!
Josh P.
Senior Moderator
