Is it possible to set up 10 machines with TV and set them up remotely
johnny77
I want to be able to install TeamViewer on about 10 brand new workstations to start with and then remote into them and set them up with all their applications remotely. Is this possible?
Hi Johnny,
Thanks for your post.
Yes - that sounds like a typical use case for TeamViewer. My recommendation is: Make a test with one workstation to find out the best possible and most efficient process for you.
As a starting point: Make sure to set up TeamViewer for unattended access with Easy access or a personal password.
On top of that, I would like to recommend you having a look at our Essential Asset Management for hasslefree support of all assets on the remote devices.
Thanks and best, Esther
Former Community Manager
