Posted by JN1480
Photon
LogMeIn
Hey guys - We are trialing this in comparison to our many year relationship with LogMeIn.
I gotta say - so far, we are RIDICULOUSLY overwhelmed.
How the heck do we just simply install the software on a client's machine, and then logon to remotely support???
We have found a dozen different ways to install, options to check, passwords to play with, policies to enforce, etc etc etc etc
Here's all I need, and then AFTER this, I can choose to learn more about the many nuances, and advanced features TeamViewer offers over LogMeIn:
1. Install the software on the client machine
2. Connect to the client machine WITHOUT the client having to accept the connection, share a password, configure  a password, configure options, etc....
3. Configure my connecting software to save the client's windows user/pass so we can log on without having to look up every time.
Help!?
1 Reply
1 Reply
Posted by jamessutton
Digon
Re: LogMeIn
Hi @JN1480
Try using unattended access as you have to create a set password in the setup so just use the same password. OR, you could just sign in as you an save contacts which saves the password also.
Hope I helped,
James
