Loosing teamviewer authentication after logout or remote desktop sessions
tobiascapin
Posts: 4 ✭✭
Hi, I have TV version 13.2.14327, I found that I frequently loosing the authentication and I cannot login again after teamviewer restart. I'm speaking of teamviewer account authentication (to see my contacts) and NOT a remote session or windows authentication.
I could say that this happens after a remote RDP session or Windows session lock to my computer. When I login back in windows, teamviewer is disconnected and I cannot login again (no error, just nothing happens after pushing Login), to solve I have to exit and restart teamviewer.
Is there any solution?
Anyone with a solution?
Happening to me as well0 -
No answer for this problem?0
So, is there a solution? I have an exactly problem: logout from TeamViewer after switching Windows session (user), and after re-login in Windows I can't login in TeamViewer (no actions after "login" button pushing), needs the TeamViewer to be fully restarted.0
Same problem discussion here:
For now the solution is to install 13.1 version.
1
