Posted by Michiel
Henagon
Reason Unknown
(Corporate account)
Since last friday (around 16:00 NL time) we've been having issues connecting to customers.
Today i'm still getting a lot of 'Reason unknown' replies when trying to connect. Abd frankly this is getting annoying our customers are located around the globe and i can't just 'drop by'.
When are these issues solved!?
Posted by Idroenergia_Srl
Henagon
Re: Reason Unknown
I reported the problem. Still no answer. The call center is always busy
Posted by Michiel
Henagon
Re: Reason Unknown
Same, can't get through to helpdesk either, not likely they will be able to do anything.
Posted by Community Manager
Re: Reason Unknown
Thank you for your reports.
Yes - unfortunately there are some issues currently. Our engineers have not yet confirmed the underlying root cause and they are working hard on bringing up our service again. Please subscribe to our status page to get the most recent updates: https://status.teamviewer.com/
Thanks and I apoligize for the issues,
Esther
Posted by Moderator Moderator
Moderator
Re: Reason Unknown
Hello Michiel,
We are currently facing technical issues.
Our developers are currently solving the issue.
You can follow the problem solving status on the following link :
TeamViewer Status page
Note: You can subscribe (by clicking on "Subscribe to updates") to our page. You will receive a quick e-mail, once the problem is fixed.
I wish you a good day.
French Community Moderator
Did my reply answer your question ? Accept it as a solution to help others.
Find this helpful ? Say thanks by clicking on the Thumbs Up button.
Re: Reason Unknown
Hi all - everything should be back to normal.
Please confirm.
Thanks and best, Esther
Posted by Michiel
Henagon
Re: Reason Unknown
Still getting some random 'Reason Unknown' here ant there, hopefuly this will resolve itself after a restart.
Posted by Bjorgvin
Digon
Re: Reason Unknown
Hi Teamviewer peeps :-)
I'm also getting random "Reason unknown" this morning, sometimes we're in luck after 2-3 tries :-(
Cheers, Björgvin/Vegagerdin
EDIT: Having problems loggin into the Management Console also, been like this for 15 minutes now:
Second EDIT: 60 minutes now
Third EDIT: I'm in now :-)
Björgvin Arnarsson
Posted by Michiel
Henagon
Re: Reason Unknown
Same problem here, i can't even connect to systems on my local lan...
And systems i was on a few minutes ago i try to reconnect suddenly give 'Reason Unknown'.
I mean it's standing 1 room away...
This has been going on since 26/10/2018... when will the issue be solved?
Posted by Pedro_A
Photon
Re: Reason Unknown
Same problem here, cannot connect more than 10 users in 4 countries.
The status update website does not seem to reflect the total unavailability of teamviewer service.
Posted by mscheurer
Trigon
Re: Reason Unknown
These problems are increasing constantly.
We are customers since the first version and over the years the service is getting worse and worse and the prces are rising constantly..
Time to look for another remote solution.
Posted by bbull
Photon
Re: Reason Unknown
We do have the ame issue. It started abou 1 or 2 weeks ago with a few partners.
-> Right now, we cant connect to anyone. Message: "Unknown Error"
-> We were unable to log into our TV account for 30 Min
Tel Support Line is busy.
We cant work here....
Re: Reason Unknown
I am sorry for the degraded performance.
The team is working to get is resolved. As always: https://status.teamviewer.com/#
Thank you for your patience and understanding.
Best, Esther
Info - Degraded performance October 29th and 30th 2018
I would like to take the chance and update you on the degraded performance we were facing at times on October 29th and 30th 2018.
Here´s a summary of what happened:
  • The issue appeared after a software update on some of our servers.
  • Affected users were not able to start new TeamViewer sessions or meetings and got the error message “Reason unknown”
  • The issue was not constant, but appearing multiple times a day.
  • Running sessions were not affected
  • The account login, the login to the Management Console and the TeamViewer Chat were not affected
  • After finding the cause of the issue and rolling back to the previous build, the issue was fixed
  • Our development is in contact with our software vendor to make sure that this won´t happen again
I apologize once again for the trouble this has caused you.
Thanks and all the best,
Esther
Posted by mscheurer
Trigon
Re: Info - Degraded performance October 29th and 30th 2018
Can not confirm. Account login using 2fa was NOT possible.
