Remote computer disappears when screen switches off
I have an issue with a remote computer running Windows 10. As soon as the screen switches off, that PC disappears from the list. Running a fresh install of the latest 32 bit version of Win10 (10.0.15063 Build 15063) and TeamViewer v12.0.81460
If TeamViewer is not in session to the remote machine (an Asus T100A) and that remote machine switches its screen off after its pre-defined period as set in the Power & sleep settings of Windows 10, it will drop out of the available list of remote computers straight away and not come back until the screen wakes up. When I look at that machine locally and wake the screen up, I notice that the TeamViewer icon in the taskbar is showing a red exclamation mark but then quickly disappears and it comes back up as available.
I have gone through all Windows 10's power settings and switched every conceivable sleep or power saving feature off, to no effect. The network is still active (not gone to sleep) because I can Skype into it even though that PC has disappeared according to TeamViewer.
Interesting though that nudging the remote with a Skype call will switch the screen on and therefore, revive it. Somewhat of an undocumented security feature! Or at least, a workaround to the above problem. But even then, only the Store app version (metro?) of Skype will do this.
The other workaround is to set the screen to never switch off. What is surprising though is if I close the lid to the remote PC, which also switches the screen off, the problem does not come into effect and the computer, despite having its lid shut and screen off, remains online to TeamViewer. BUT if I set the screen to switch off in Power & sleep settings AND close the lid, after the pre-determined time the PC will drop off the list.
  • EdG0000
    EdG0000 Posts: 2
    I have the exact same problem. TeamViewer was working fine for many months but then a couple of weeks ago the remote computer started disappearing from the My Computers list as soon as the PC display shuts off. The remote PC is set to never sleep, so that's not the issue. I'm using TV version 12.0.82216 on both PCs.
    Interestingly, **bleep** still recognizes the PC when the screen is off, even though TeamViewer does not. So the problem seems to be something in TeamViewer that changed.
    Since I prefer TeamViewer over Chrome RD, the workaround I use is to access the remote PC using Chrome RD and, once the screen is on and TeamViewer can see the PC, I use TeamViewer. It's inelegant and kludgy but works.
  • Wobbly
    Wobbly Posts: 5
    Thanks for replying. That was my first ever post here and I couldn't figure out if it actually posted because I couldn't see it anywhere. But sorry to hear you are having problems.
    The workaround of switching the screen timeout off altogether is holding up.
    But I'm interested in what your saying because that computer located 300 kilometres away now has another problem whereby TeamViewer has completely locked up. I was in a session but let it go idle for about half an hour. When I went to go back to it, the remote machine was unresponsive and I can't open up another session to it although that PC is still available in the list. That is a completely separate issue I need to work out.
    But I also now have to sort out another RD protocol such as Chrome to run alongside the other so when one fails, I can use something else to kick the frozen one in the guts. Strange but true.
  • EdG0000
    EdG0000 Posts: 2
    It would be nice if someone from TeamViewer actually monitored and responded to these posts!
    My use case is different in that I use TeamViewer mostly to access my home PCs when I'm at work. I'm a user and not an IT guy I'm afraid. I haven't had the second problem you describe. The only other issue I've had is losing the remote PC altogether in TeamViewer becuase the remote PC lost power and went to sleep. I don't use the Wake on LAN option but might try that.
    What I find strange is that it used to work fine and suddenly stopped when nothing changed on the remote PC, and that it works fine with **bleep**, which is free. I'm not sure if the problem started after a TeamViewer upgrade or not.
