Posted by JohnBruurmijn
Henagon
Removal of information screen at first logon when Teamviewer Host is installed
Removal of information screen at first logon when Teamviewer Host is installed.
I created an unattended installation for teamviewer containing the setup, en connected quicksupport settings and the teamviewer settings (.reg) file. All is working fine but when a user logs on for the first time to a system where this is installed, they will get an information screen with the ID and where to find the teamviewer program (system tray). Is there a way to skip this for all users? We do not need the information provided unless we ask for it and at that point we will need to explain to the user where to look. Maybe I can add a setting as default saying 'do not show dialog' so this is alreadt set before the first screen appears?
1 Accepted Solution
Accepted Solutions
Posted by Former Staff Benjamin_B
Former Staff
Solution
Re: Removal of information screen at first logon when Teamviewer Host is installed
This question has been answered in this thread .
I hope this helps. Good luck!
Project Manager Community
View solution in original post
Posted by Chiron
Hexagon
Same issue here. And not just the host version. It would be nice to keep the full version from poping up also.
Former Staff
Solution
Henagon
I added this information to the teamviewer_settings.reg and this works like a charm!
