Posted by AREZOO
Photon
TEAMVIEWER BLOCKED IP FROM IRAN
hello , i am from iran , formerly you did not block ip from iran , but since trupm (is stupid ) is president of usa , you did block ips from iran ,   but google and microsoft did not block ips from iran , they are american companies , you are a germany company but you did block ips from iran , in iran there is not copyright but for this also Microsoft not did block ips from iran , but you did , in iran so many people and offices of government and private, used teamviewer , and also in universities professors said  about and use from teamviewer ,Benz company also is from germany and works in usa and now in iran , but did not block work in iran
something that you do not know , maybe until spring Iran Join Universal Copyright  and a person who that is the loser is you , because people use another softwares now and They will get used to them
you also are stupid like trump
thank you
Posted by barkeeper
Photon
Re: TEAMVIEWER BLOCKED IP FROM IRAN
nah man, your negative public opinion - on something the creators of Teamviewer can't help (it's the ISP's problem) - and not being very constructive - is trash ; ]
Posted by Midosi
Henagon
I can confirm that too. Limited UDP protocol by some of ISPs in Iran.
But you can definitely fine a solution for this. Like possiblity to set a proxy server in TW client.
