Announcements
TeamViewer 14.5 has been released. See the Change Logs here.
Posted by loopygram
Henagon
Taskbar frozen
I have used the free Teamviewer for a few years now.  I have a laptop on the main floor and  my other laptop is on the 2nd floor.   I work on it a lot from the main floor.
The taskbar has frozen on the remote laptop and I can't seem to fix it.   Any keystrokes I use to start Task Manager, of course, is the Task Manager for the laptop I'm using.  Is there a way to restart the remote laptop or fix the taskbar on the remote one.
Also would like to ask if there is a way to always use the same password.  Every time I start Team Viewer I have to run upstairs to find out the password.
Thank you.
