Announcements
Remote Control for all devices running Android 7+ is here!
(Incl. Google Pixel series, Xiaomi smartphones, Oppo devices, and many more)
Learn more
Highlighted
Posted by
Electron
Team Viewer Corporate Disable Remote Input and Black Screen greyed out
The Disable Remote Input and Black Screen checkmarks are greyed out on Mac.
Can it be enabled?
1 Reply
1 Accepted Solution
Accepted Solutions
Highlighted
Posted by Community Manager
Solution
Re: Team Viewer Corporate Disable Remote Input and Black Screen greyed out
HI @LayneStaley
Thanks for your post.
We created a description you can use to check whether the setup on your device is correct: https://community.teamviewer.com/t5/Knowledge-Base/TeamViewer-Black-Screen/ta-p/50966#toc-hId--44213...
Hope this helps,
Esther
Find this helpful? Say thanks by clicking on the Thumbs Up button. Find more information here: Knowledge Base | Community Blog | How to get started
View solution in original post
1 Reply
Highlighted
Solution
HI @LayneStaley
Hope this helps,
Esther
