Announcements
Remote Control for all devices running Android 7+ is here!
(Incl. Google Pixel series, Xiaomi smartphones, Oppo devices, and many more)
Learn more
Highlighted
Posted by
Hexagon
Re: Suspected commercial use?
Actually we the free users we don't generate ANY revenue, while we do probably use TV resources (when connecting over the Internet, we go through their servers, so that must use bandwith and CPU power), maybe they don't want this anymore. I'm sure (anyway I hope that this is the case) that if we were paying customers, our issues would have been solved.
Highlighted
Posted by
Photon
Using a free subscription but Teamviewer consider the opposite? Why?
Highlighted
Posted by
Henagon
Re: Using a free subscription but Teamviewer consider the opposite? Why?
TeamViewer should be complelled to provide us with the specific "analysis of product usage" that they believe gives them "reason to believe you are using the product in a commercial context."
I received this email today despite only using TeamViewer to help a single visually-impaired 88 year-old family friend with very rare email and print assistance. My own logs indicate that I used it 2-3 days per month since February and the sessions were typically 5-20 minutes.
Sending these letters apparently at random to even the most light-ended personal users and demanding a tedious process of printing, filling out, scanning and then emailing back a paper does not bode well for this company's overall public perception.
Highlighted
Posted by
Electron
Suspected commercial usage...
Apparently Teamviewer is considering I'm using the software in a commercial use.  I'm using it very regularly, but this is to perform daily tasks on the computer of my wife to support her in her daily work. This is of course unpaid and has no commercial purpose at all... : I will not be charging my wife for helping her out with her pc....????
I've filled out the form but I'm wondering how long this will take before I can again use Teamviewer properly...
Highlighted
Posted by
Digon
commercial use detected after upgrade of Teamviewer
Why is it that every time I do an upgrade of my Teamviewer program I am again and again accused of using the software commercially when I already on previous versions am accepted as a personal user? I am running teamviewer for the most on 2 computers sitting next to each other to avoid having a desk full of keyboards.....
Highlighted
Posted by
Pentagon
Re: Suspected commercial usage...
For me it took five weeks.
Highlighted
Posted by
Henagon
Re: TeamViewer thinks I’m using the software commercially!
I have been using Teamviewer just fine for literally over a year. Suddenly I am receiving timeouts and refusal to connect. I connect to only 1 single machine and this machine is in the same private house as me. I rarely connect from outside, usually I connect via LAN.
Now, I can only connect to it for 1 minute before being timed out and told I must wait 10 minutes to reconnect. This is absolutely disgusting, I can't believe that Teamviewer would be so victimising as to do this. This is completely unacceptable and the notion of filing in a form to wait weeks to be 'unblocked' is outrageous.
I will no longer be using Teamviewer and I will switch to a competitor that doesn't bully their free customers. If Teamviewer wants to be like this, I suggest they tell customers in advance that if they are suspected of commercial usage then they will be victimised and bullied to the point where they cannot use Teamviewer without forking over a load of cash for something they simply do not need.
Highlighted
Posted by Moderator Moderator
Moderator
Re: commercial use detected after upgrade of Teamviewer
Hi @FrodeE,
Thankyou for your post.
Based on your case, kindly visit the page TeamViewer Commercial Use Suspected and resubmit the requests for both IDs please. So we may look at both TeamViewer IDs again.
Highlighted
Posted by
Electron
Notice about commercial usage suspected...
Apparently I am not the only one getting this idiotic email. I don't know what usage the geniuses at TV are "analysing" but they might give some thought to providing a form with editable fields that you can actually attach to the Personal Use Verification form. It smells more like strongarming people into buying the commercial version--and the appalling lack of support that comes with it when it fails.
And then they want you to wait thirty days before the sluggards get around to upgrading it--maybe sooner though. ;-/
I've tried repeatedly to use your online personal verification form and it isn't working. You can throttle me if you like. I think it's time to find a more congenial software provider whose client does the same thing without the threats and the annoyance.
Highlighted
Posted by
Henagon
Re: Notice about commercial usage suspected...
Having the exactly same problem. If they dont "fix" it, I'm looking at other alternatives.
Feels like the free users are forced into buying, and with the horrid prices, it ain't gonna happen.
Highlighted
Posted by Senior Moderator Senior Moderator
Senior Moderator
Hi @Maximiliann
Can you please check which versions you use on both sides? Please make sure to use TeamViewer version 14 on both devices.
If you are already on version 14, it might be helpful to uninstall TV14 on both sides and reinstall it. If this does not help, the only way is to fill in the "Commercial Use Suspected" form.
Thank you very much in advance and have a great start into the new week.
Natascha
Highlighted
Posted by
Electron
from private to commercial problem
I have been using team viewer for several years.
I use this system to transfer data from one private computer to another
suddenly the report appeared a few days ago.
Commercial Use suspected/detected:
I only use Teamviewer privately and I can't use it commercially because I don't have a business of my own
Since then, team viewer no longer works.
what is going on.
How can I solve this
Highlighted
Posted by
Henagon
Commerical Use to Personal Use
I purchased a new computer (computer A) and a TeamViewer commercial license together back then, approximately 4-5 years ago.  I left the company I was working for but still had the computer and license, as they were mine.  Throughout TeamViewer updates (I think starting with 11, 12, 13 and now 14), I've left TeamViewer as is in computer A, meaning I didn't uninstall and switch to personal; I kept it as is which is commercial.  Now with 14, I only have five minutes of usage per session or something like that, from computer A to any other computer.
I recently put in my third request to change computer Ato personal but I'm having no luck.  I've been putting my requests in more than seven days apart.  I've de-linked computer A to the business TeamViewer account.  I have two TeamViewer accounts, one for business and one for personal.  I don't use the business account anymore.
Since I'm having no luck, what are my options?  Should I downgrade all my computers to 11 so that I can use computer A to others, without any problems?  Will that even work?
Highlighted
Posted by Closed account
Not applicable
As a long-time, 10+ year free user who uses the product simply to remote into my second PC and start music playlists, I will be ceasing all use and recommendations of this product. The horrible customer support experience I encountered after trying to reach out and resolve the email I received about being suspected of commercial use has convinced me that TeamViewer is not running an ethical business any longer.
Three times in rapid succession, the sales department attempted to persuade me to divulge my personal phone number so that they could attempt to sell me the product. After telling them no each time, they replied within milliseconds with an intricate and long sentence, indicating that they are simply following screen prompts asking if the customer agreed to allow them to call or not - or worse they are a bot.
The rather large company at which I am employed currently uses the commercial version of TeamViewer, and when time comes to renew the license, I, being solely in charge of such decisions, will be sure we decline and find another product, as superior products are now on the market at competitive pricing.
Let me leave a friendly warning that if you do not take this kind of feedback seriously, revise your customer service policies, and stop **bleep**ing off your free users - who are your BIGGEST ADVOCATES mind you - you will see dramatic losses in renewed and future sales in addition to establishing a horrible reputation from which it will be nearly impossible to recover consumer confidence.
The choice is yours to make TeamViewer. I know if it were my call, I'd stop the bleeding now and make apologies. The internet never forgets.
Highlighted
Not applicable
I've moved to another product which I have never used before and is awesome.
Just have a look around people  and you will find another product that works a lot better without any issues or prompts.
Haha i didnt say a name of another product and got starred out, TV must be really paranoid to star out third party product names.
bye
Highlighted
Posted by
Trigon
So what dces it rhyme with, or maybe a riddle?
Highlighted
Posted by
Hexagon
@stevep : unfortunately he has closed his account so he won't be able to answer us anymore.
Highlighted
Posted by
Trigon
Nothing draconian there, then...
Highlighted
Posted by
Henagon
How to change commercial use to personal use?
Hi everbody,
I urgently need help in solving my problem with teamviewer.
I have another pc install accidentally on commercial use then the trial period expired. I uninstall and install back with personal use (  5 times installation been done) but after install, its say trial period expired and gives me the same commercial ID. Along with that i can't connect to my pc. Kindly please help me to solve this problem.
Highlighted
Moderator
Re: How to change commercial use to personal use?
Hi @jonaz ,
thanks for reaching out. Welcome to the Community!
Please find here more information Why do I see TeamViewer trial - 'Your trial period has expired' ?
Let us know if you need more information. Have a nice weekend :)
Alena
Spanish Community Moderator
If my reply answered your question, help out other users and click the Accept as a Solution  button below. You can also say thanks by clicking on the Thumbs Up button!
English Community |  Deutsche Community | 日本語コミュニティ |  中文社区 | Communauté française | Comunidad española
Highlighted
Posted by
Henagon
Re: change teamviewer version 13 company to personal
I have this exact same problem when I set up a new personal laptop and misclicked the wrong box for version 14 and am needing the same fix or soluation for my laptop.
Highlighted
Posted by
Photon
Business use warning
You keep popping a warning when starting teamviewer, about using the program in business relation environment.  ..duh!.. i am sometimes using my company computer to connect to my private, at home.
please stop cutting the connection after 5 minutes. It is ridiculous. I have already accepted and agreed that it is used as a private person. If my company would invest and use teamviewer it would be great, but they have other deals, and security policies, which teamviewer apparently couldn’t live up to. I don’t see why it should keep me from using this great product, as a private person.
If it works, don't fix it.
Highlighted
Posted by
Henagon
suspected commercial use
TW says it seems i'm useing a commercial version but is not true-I use tw from my home to take control of pc i have at my mother house to control radio,I'm a radio operator
Highlighted
Posted by
Photon
Commercial Use Detected!!!
Lately I've received the dreaded "commercial use detected" from my account. Didn't think much of it, more than that it's wrong. My computer runs Windows 7 Pro. Accessing my HTPC, running Windows 10 to control the music this happens every time. Same thing happens when I access my Windows 7 computer from my Windows Mobile (yea I'm one of the few still using them...) or the HTPC
However, from my Android phone or tablet, accessing my Windows 7 computer this does not occur, which makes be believe it is something with Windows 7 connection to and from certain units. Any thoughts?
Highlighted
Posted by
Henagon
Free vs. License
I've used my personal use TeamViewer without trouble until today. Now I'm booted out after 5 or 10 minutes. What's happening?
Highlighted
Posted by
Photon
TeamViewer in academia
I am using Team Viewer to help me with my PhD research (when I need to access my workstation at university on weekends or on holidays to run scripts). Is that a commercial use? I didn't see any clear statement from the TeamViewer team on it. If yes I am happy to pay for an academic license; however, the current licensing scheme doesn't discriminate between students and business, while the amount of money in the pocket is clearly different for these groups :/
Aga
Highlighted
Posted by
Henagon
Re: Commercial Use Detected!!!
I have some thoughts about this. This is not about them having 'detected' commercial usage on your system. This is all about new avenues of monetizing for them and pressuring users into buying into a commercial license.
This nonsense started for me a few weeks ago as well, after which I submitted a request online to unblock the account -- which is not being used for commercial puposes whatsoever.
Today I received an email stating that they were unable to discern private usage.  If they actually capture any of these sessions for commercial usage detection (using some machine learning algorithm) they have some work to do, because some of that usage with my girlfriend has been anything but commercial.
The only thing that did change is that I started using OpenVPN to dial into my home network to ensure an encrypted connection from wherever I use my laptop. The changing IP networks is probably what triggering this nonsense. I have no intention on changing that as there are more than enough alternatives to TeamViewer.
ps. The mail I received today also had a link to a printed form that is laden with spelling mistakes and duplicate fields. You might want to look into that dear people at TeamViewer GmbH, it comes across amateurish.
Highlighted
Posted by
Henagon
No license Moves Left
I have changed my pc and now i am not allowed to perform any changes on using any platform.
Please reset my moves again.
Thanks.
Highlighted
Posted by
Electron
Exactly the same here, and I just use it to my own pc from my phone, had the mail saying they’re unable to confirm private use. I mean, I’m not using it to get any sort of payment and just play Webb games when not able to move to pc, their algorithms for commercial use detection is just broken and pushes me away tbh, after years of using it this way it’s suddenly commercial? And if they accept the form which I have little to none hope for, will they do this again later on for the same week wait then what ever the wait is to accept the form? :/
Highlighted
Posted by
Henagon
Wrong supposed business use
Teamviewer derived that I'm doing a professional user of their software, and thus restricted the session to few minutes. I dont know what sort of algorithm are they using, but it is wrong in my case. I'm retired and I have no business activity. As it is a free use, I cant get any support. Any idea to restore my normal use ?
Highlighted
Posted by
Electron
Re: Wrong supposed business use
My account has also been flagged as business use, I am connecting to my home PC from an android tablet purely for personal use.
Highlighted
Posted by
Digon
All bad - Wrong commercial use, 30s timeout, 10 minute wait
I started getting a warning that it looked as thought I was using TV for commercial use; I'm not, and to avoid future problems I wrote to explain why this was a false positive. Now, they do say it can take up to a week to deal with such things (!) but a few days later I try to connect as usual and am told there is a maximum session duration and to try again in ~10 minutes. When I do the connection lasts ~30s then times out again.
It is now impossible to use TV in accordance with the free license terms!
This is infurating given that I tried to address this issue in advance - the very least they could do is put a "hold" on any blocks given that I provided my IDs and other a/c information.
What does TV plan to do to resolve these issues for me and other legitimate users of the fre license - which TV actually offers!? W|e don't get support but they do get useful data from our usage and recommendations... which I am now seriously thinking about broadcasting retractions of.
Sadly, since this is the "community" all I actually expect is a lot of "me too's" but just in case TV is listening...
Highlighted
Posted by
Henagon
Commercial Use?
I know there’s like a billion posts here regarding false positives, but I thought I’d make my independent post to that TeamViewer can look into my usage and determine the real use of my account.
I simply only ever remote into my home computers (Windows and Mac) from my iPhone, and now I’ve been flagged for commercial use.
Could you please look into it and remove the false positive?
Thanks,
Highlighted
Posted by
Photon
Another complaint about supposed commercial use
Nothing new now, as per the other recent threads.
Got a "COMMERCIAL USE DETECTED", I assume because I use TV all the time - although it's always between just from one of my machines to another, entirely personal. So ok, it said the session will be terminated after 5 minutes, I thought ok that's enough time to do what I need to do. But no, it terminated after 27 seconds, and of course the subsequent connection attempt was blocked and I have to wait 10 minutes... for what, another 27 seconds connection time?
Granted I'm using the free version, but way to drive people away from your product! Today I'll be looking into alternative products since obviously TV no longer wants anyone using its free version... would be better if they just annonuced they'll be retiring the free version on some date rather than attempting to force people away by making their usage expeience as unpleasant as possible. I'm expecting the next update to install a virus on the client machine, "HA THAT'S WHAT YOU GET FOR DARING TO USE THE FREE VERSION!"
Highlighted
Posted by
Henagon
Re: Commercial Use?
i use teamviwer from my office computer to connect to my home computer (only in that way) for personal stuff, not any commercial stuff. is it considered like commercial use ?
Highlighted
Posted by
Digon
Commercial use suspected
Im using TW 10 years in last 3 years what happents i dont know all the time lock and im use it in my home network not commercial and all the time this is get locked
Please fix this it looks like you do it just to annoyng the free users until to change programm or to buy lol!
How can be commercial in the same lan ? omg .......
Highlighted
Posted by
Henagon
Re: Commercial use suspected
Just fill form here
https://www.teamviewer.com/en/support/commercial-use-suspected
I had same issuse with teamviewer for about 3-4 times on 4 years peroid.
Highlighted
Posted by
Henagon
Re: Commercial Use?
Just fill form here
Highlighted
Posted by
Atom
Look for alternatives
They're not offering any solutions to blocking you and I
Highlighted
Posted by
Hexagon
Re: Look for alternatives
@FormerUser : as announced, TV 9 stopped working for me, I switched back to version 14 and at least for now it works; I noticed a difference on Android, though: each time I launch it it activates itself (so it's a bit slower at the beginning)
Highlighted
Posted by
Digon
I already filed the form,multiple times !
I get told between all my machines and my phone it's commercial... (and your reply was that it was reset to commercial! Yet it's still the same!)
Highlighted
Posted by
Hexagon
@Xandor : who exactly told you that?!? I too use phone to PC (but most of the time I'm in the same network, it's just a convenience to monitor it from another room).
Highlighted
Posted by
Digon
@pv7721 I sent the form I was told to, and got the following back:
Dear TeamViewer User,
Thank you for getting in touch with us. We are happy to inform you that your TeamViewer ID has been reset to “free”. After reviewing your request, we decided that your use case can be qualified as “personal”.
Highlighted
Posted by
Hexagon
so it's ok for you or not yet? Have you restarted TV?
Highlighted
Posted by
Digon
Mainly using it between my computers and my mobile, and it's not fixed on any of them.... even after multiple restarts.. the mail I received with it being reset was 1 1/2 week ago...
Their whole new system is a farce and a joke and will do nothing but push away customers..
(I use it at work as well, but other other accounts, I am closing those down now.. not gonna bother supporting team viewer with the **bleep** they are pulling.. )
Highlighted
Posted by
Hexagon
@Xandor : oh I see, I did the following: filled out the form for ALL the IDs I've been using (my PC, my mum's and brother's) because they say you have to do it like this; if you do it for only one ID, your account might get flagged again for the other IDs. I did receive only one reset to free (but they don't say for which one was) and I've also received a form to sign and send back. Eventually the warnings and flagging stopped, but I wonder what'll happen in version 15 (and by the way, the workaround to going back to version 9 and stay there without updating is no longer working, as they've deprecated this version, and you got automatically disconnected after 5 minutes).
Highlighted
Posted by
Henagon
How do I submit this form?
I am getting the exact same message about commercial use.
When I try to contact Teamviewer it says you cannot unless you have a Licence.
Thanks.
Highlighted
Posted by
Hexagon
Highlighted
Posted by
Henagon
Thank you. I have submitted a ticket. I hope this works.
Highlighted
Posted by
Hexagon
@Cjm1975 : You're welcome. Hope always dies last.
