Posted by Closed account
Not applicable
Commercial use detected
I am getting following message when I am trying to get connected from my home private computer to another private computer. I want to use the free version. Any idea, how the problem can be solved?
Posted by vitinholima2001
Henagon
Business Account Usage Detection
Hello. I'm having trouble using my TeamViewer account, that detected commercial use, however this is not true. My main use is with family members who need assistance. How can I solve this?
Posted by vice86
Trigon
Re: Commercial use detected
what did Teamviewer change that sooooo many free users are now getting this false positive?
Posted by bhowes
Digon
Re: "Commercial use Suspected" form doesn't work.
I got a warning - all I did was take an old mac pro and connect to it and it said commercial use detected (not suspected). On my home network with my home machines!
Posted by vice86
Trigon
Re: Scam scam scam
If they charged 5.00/month or something, i could see that but no one's gonna think "oh well, i might as well [The price has been removed as per the community guidelines]" when there's other free options. I think there's a screw up on their end that they're just not owning up to.
EDIT: Wow, they censor the word that's used to describe how you install a lightbulb into a socket...sc**w
Posted by kgonepostl
Electron
Re: Scam scam scam
What's more likely. The fact that they are a business, and are doing this on purpose, for more money. Or that they are working hard at fixing this problem for free users?? I'm sorry, I respectfully disagree with that notion. It's been an issue for quite a while. Occam's razor
Posted by icoskey
Henagon
Re: Business Account Usage Detection
Same issue.  I support my in-laws and parents who are technology challenged.  I am using TeamViewer for business purposes.  I am getting the "Commercial Use detected" error.  How can I stop this error?
Posted by April1904
Proton
time out
I'm using teamviews for personal, but I always got kick out from teamviews with a reason time out session .... what can I do ?
Posted by rbmoving
Digon
TeamViewer14; Win10...Limiting Use
When I attempt to start a session with another it displays something like you are allotted 5 min Duration...you cannot connect (it shows a time)....
It might have displayed something about commercial use....not sure; my installed Version displays FREE LICENSE-NON-COOMERIAL USE ONLY..and so does the other persons installed Copy.  I went ahead and uninstalled my version...and re-installed TV14...checked PERSONAL USE ONLY.....so did the other person....
Todays date 8/31/19...does anyone know if this is a TeamViewer Server Issue?  I don't know what esle to try; thought New Installs might resolve, but it did not....
Posted by vice86
Trigon
Re: TeamViewer thinks I’m using the software commercially!
3 days since being "fixed" i'm getting commercial use flag again...lol. Teamviewer stinks.
Posted by duderonomy
Trigon
That's good customer focus.
Run don't walk toward the exits!
Posted by vice86
Trigon
I've given up on TV and use **Third Party Product** now. I was just curious to see how long .my free usage would last after being fixed. 3 whole days lol
Trigon
It was very useful info to share. I am grateful for your post. It helps us know that we made the right decision. Take care and good luck!
Posted by Joas_alc
Henagon
I got the same message for my laptop and my phone. Can somebody help me?
Posted by vice86
Trigon
You have to waste your time filling out this >> https://www.teamviewer.com/en/support/commercial-use-suspected/
only for the flag to come back a few days later.
Posted by Joas_alc
Henagon
Thank you very much!
Posted by ssybesma
Trigon
It seemed that way for me for a while and then within a couple weeks all the notices finally stopped. They never tell you when they fix anything...you just find out. I made sure to provide them a list of ALL my machines names and IDs (not just the ones I saw the notices on). They can't seem to tell a business user from a hole in the ground. I only use TV on my home machines and occasionally those of my family to remote in and fix issues with them. All personal use. Never commercial use.
Posted by vice86
Trigon
Hmm that may be my issue. I gave them one ID thinking both PCs have the same ID. Will look again.
Posted by ssybesma
Trigon
Yeah, I figured give them info on all the machines, because sometimes it's hard to figure which machine is generating the complaint. It could be all of them, or just some of them. I noticed also if you ever run TeamViewer on a VM it will automatically give you that error and you have to beg them to exclude that also. When they do add the exception for the VM, you need to track the MAC address of that VMs network adapter to make sure it never changes (so you can change back to the original if needed). Changing a MAC address changes the TeamViewer ID (or rather, will require changing the ID) and you start that problem over again. I ran into that once.
Posted by attorney
Digon
What is so frustrating is it is inconsistent. I ran team viewer on the virtual machine for a long time because it made it simpler for me I ran a VM inside of my disk drive because I wanted to be able to access my files and I didn’t have any problem with that. But the minute I ran it on Ubuntu because I was curious how that worked well that immediately triggered a problem that never went away. I’ve given them all of the different IDs of all of my machine and it didn’t seem to matter. The bottom line is they don’t really support private use.
And I would respect that if they would be open about that but this cloak and dagger maybe it works maybe it doesn’t and you will only find out when you need it and it doesn’t work, that has forced me to switch to other choices like the remote option built into *** Third Party Product*** etc. They’re not as good but they work and you won’t get caught needing it and not having it.
Posted by ssybesma
Trigon
My theory is that TV uses mainly the MAC address to identify the machine that's being connected to. It can also identify the OS separately and that's why you will get the notice if running a server OS. If either the MAC address or the OS (or both) changes, then basically you have to get a new TeamViewer ID. I'm pretty sure I got an exemption on a VM once when I submitted the information for it to them. Thing is that each VM you create will give a different MAC address. If you're in Virtualbox and switch to or create a different VM, you get a different MAC address and that means you get a different TeamViewer ID. Once the TV ID on a VM is set as 'personal use' in their database and you don't use it to connect to a commercial-use machine or vice versa, you should be good to go permanently as long neither the MAC address nor the OS change. A word about MAC addresses generated by Virtualbox...since the first three octets of the MAC address (called the OUI) identify the manufacturer of the network adapter, I believe that will always trigger the notice from TeamViewer and that's why you have to get each of those VMs exempted. Anyone who knows better than this is welcome to correct me if I'm wrong but I'm pretty sure that's close to the truth. The 'manufacturer' (08:00:27) that Virtualbox uses for its MAC addresses according to the OUI database is CADMUS COMPUTER SYSTEMS which is long out of business and may have been purchased by DEC. It seems TeamViewer flags all of those it sees.
Posted by Glassdub
Pentagon
Nope, I flip the mac address on my notebook several times a night if this was the case I could log on without this issue.
Posted by ssybesma
Trigon
You have to fill out their form with your name, machine's name and TeamViewer ID and wait at least a week and they should remove the restriction on your machine. Total pain, I know.
Posted by ssybesma
Trigon
Re: TeamViewer14; Win10...Limiting Use
Fill out the form to get ALL of your machines exempted from their false positive. You have to do ALL of your machines at once or you will be playing whack-a-mole. If ANY machine appears as commercial use, you violate even by connecting to it from a machine that was previously deemed to be personal use, then that previously personal use machine can technically get stuck with the commercial use restriction also.
Posted by ssybesma
Trigon
Yep, you can't make any change to it or else TeamViewer sees it as a completely new machine with another red-flagged MAC address. If you want to use another one you'll have to go through that hoop all over again. I assume you're using Virtualbox for the VM or are you using VMWare? I think they both have the same problem but thing about Virtualbox is that it never registered the MAC address range that it uses, at least that anyone knows of.
Posted by rodspc
Henagon
Re: Has ANYONE had their commercial use block removed....
I got an email said it had been reset to free. Guess what.... first time I use it got the same **bleep** ...commercial use. I replied to the email and have yet to get a response.
Posted by DanLester
Trigon
Re: Commercial Use Detected
OK, I tried to do this, and got hung up with this
Where the **bleep** is the recaptcha???
Later edit: ah, what they don't tell you is that you need to be using Chrome. Firefox won't show that recaptcha. Real **bleep**er.
Posted by jtalstad
Neutron
Same experience and question here...
Posted by DanLester
Trigon
OK, having figured out that you needed to use Chrome to fill out the form in https://www.teamviewer.com/en/support/commercial-use-suspected/
I registered my complaint and got a message saying they would look into it. We shall see. In the meantime, [removed per Community Guidelines] Nothing really making me want to stay with TeamViewer, given this "Commercial use Suspected" trash.
Posted by johnzageek
Digon
Teamviewer is getting lamer by the day
Posted by vice86
Trigon
The censoring is useless if your subscribed to the topic. We get alerts of new messages and it shows what's said before the censor
Digon
Since when has a community of users become outlaw's. What a croc of **BLEEP**...
Posted by picard80
Henagon
Re: "Your license limits the maximum session duration" for FREE personal use
Teamviewer is actively trying to get rid of user who do not pay for a commercial license. Instead of simply admitting it, they enforce these stupid pop-ups.
Posted by DanLester
Trigon
You know, in it's day, TeamViewer was da king. It was fantastic in that it offered the oportunity to leanover someone's shoulder working on their computer. But there are many good options now to do that that don't fall back on "Commercial use Suspected". TeamViewer does have some nice features, though.
Hard to rant about a community of users that have become outlaws. I don't pay TeamViewer anything. They are generous to let me use their system for free. I'm getting something for nothing, which could make me an outlaw. But I'd at least like to be treated consistently.
Posted by cobalt503
Neutron
I'm looking into alternatives right now because I am tired of this nonsense. I've been a loyal fan of teamviewer and if they had a reasonable price for one time purchase I would totally buy it. Or even a 30$/ year license I could get behind for my personal use. But 50$ a month is stupid rediculous when there are at least 5 options for free.
Posted by rbmoving
Digon
[removed per Community Guidelines] seems to me it is a waste of time to fill out the form to get a wrongful identified acct changed to personal when in days it just goes back to commercial.. Sounds to me this is a detection software poorly designed and implemented that is inpropely determining Commercial use of the software.  I use it for personal only, guessing the last time I used it other than yesterday when I got the Duration Time notification...was abiut 6 weeks ago.
Posted by DanLester
Trigon
Wish I could, but the TeamViewer Community website is tuned not to let you list commercial products - [removed per Community Guidelines] Both are free, but you can buy more sophisticated options on the latter, which I don't need. There are others as well.
I have all three engaged in my system, so I can have confidence that, whatever happens, I'll be able to get through.
Posted by wraythompson
Henagon
Re: I was detected as "Commercial Use" but you wrote back and said I was set back to "Free", but I s
Exactly the same issue with me and Teamviewer does not respond. I guess they now want to generate revenue from personal use. Only thing I changed was my ISP
Posted by Moderator Moderator
Moderator
Hello everyone,
thanks for your posts. We are sorry to hear that you are still unable to use TeamViewer.
If you did get the confirmation that your ID was reset, please remember that it could be necessary to restart TeamViewer.
If you are still not able to connect that means, that the remote side is the one flagged as "commercial use" and then the next step would be to send us the request also for the remote device.
Note:  please note that when you submit the form, it is only for a single ID. That means that if you want to reset several IDs, we need ONE FORM for EACH ID. Please see the form here: www.teamviewer.com/reset
Please note that this is fully explained in our article: Why do I see 'Commercial use suspected' / 'Commercial use detected'
Best, Alena
Spanish Community Moderator
If my reply answered your question, help out other users and click the Accept as a Solution  button below. You can also say thanks by clicking on the Thumbs Up button!
English Community |  Deutsche Community | 日本語コミュニティ |  中文社区 | Communauté française | Comunidad española
Posted by nobu
Henagon
Re: Reset to free but nothing change
Thank you, but it did not work for me.
I tried everything. Both TVs are updated, I got even the "set to free confirmation" for my parents, i reinstalled the TVs after cleaning every trace of it, i even tried the portable version of TV.
I allways get immediately the kommercial use claim and the 5 min limit but then get thrown out after only 20 seconds.
My parents would even pay but not as much and not for an application with defect licensing.
Is there realy no hope and no one responsible? No one to turn to?
Posted by rbmoving
Digon
In my opinion, this issue casts a very poor image of TV...poor treatment of customers service, poor image of something they employed that should properly detect Commercial users and it is not.....poor design and implementation from a company who should be highly sophisticated when it comes to software.  It is clear many of us have been wrongfully accused of using TV for commercial use. Fill out a form, maybe TV agrees you are not using the Software for commercial use, wait a week or more for maybe a response, than others who got the response have written here that after only a few days get ID'ed as a commercial user again...then complete yet another form....it nothing more than making lots of people talk about TV in a very negative way.  Shame on TV....this treatment is unexcusable...and the service provided...gets a D(-)
Posted by kfsutops
Trigon
I go the dreaded message today out of the blue. Been using the software for years now connecting to one computer, using one computer. Never used it for more than one computer.
I understand the need to potentially catch people using your software outside the scope of design but really. I use it for one computer so I don't have to go upstairs.
The bad part is nobody can really answer why TV declares it's commercial use. Shady and I will no longer recommend this product.
Posted by rbmoving
Digon
I can write negative comments...and when things I hope are made right...I will always write Positive comments in Thanks.  Coincident or not, in about 12 hours from my earlier Posting of today expressing my disappointment with TV as recognized me as a commercial User when that was not so...I got the form email from TV advising I was no longer identified as a Commercial User.  I had also sent the form 3 days ago that is available in this form....so was it my Post or the form...and does it even matter...TV thus far has made it right.  I have read where others who got this same email...no longer recognized as a Commercial user...only to be recognized as a Commercial User again.
I want to Thank TV for resolved my issue, removing the Commercial User status...and it is my hope that TV is using my findings as well as others to Tweak whatever monitoring software is in use to identify those that are using TV Commercially to the harm and disadvantage of those of us who are using TV honestly...for personal use.
Again; thank you TV......after getting your email I did connect with my sister for a few seconds and that popup Notification about durations, etc...did not appear.  I hope it remains in the Free License (Non Commercial use Only) Status
Posted by vice86
Trigon
It took them 10 days to finally fix my account but I appreciate it. There's other options but I'm just used to TeamViewer and I like it. Only thing is I didn't know I had to report each ID, so while one PC is good for free use, my other is still flagged. I filled out the form again for the other ID. Now I just wait for them to set that to free and I'll be good to go :)
So far 6 days in on the fixed ID and no false flags yet like some are getting after the fix.
Posted by tankhimo
Electron
Re: ID set as free but still shows Trial Expired
I restarted service and the entire PC. Still shows "trial expired". Is it a bug in version 14?
Posted by iouiou
Henagon
unblock me pls
i need to be set back to a free user cant find ticket used it the other day and phone number hangs up when I hit I have free account can I get an message so I can send the right user id
Posted by bigolebear
Henagon
free version vs commercial
i have used the free version for years helping friends and family. today TV believes im using it for commercial use. any ideas how to resolve this?
Posted by halani
Henagon
Re: free version vs commercial
I have the same **bleep** problem from my personal mobile phone to my personal desktop. This is Irritating. I spoke with someone from TeamViewer and they wanted me to pay [The price has been removed as per the community guidelines.] a year to allow the connection.
**bleep** that and **bleep** TeamViewer. I have been trying to find an alternative without any luck.
Posted by DanLester
Trigon
As noted, there are several good options for control of a remote computer.The question is, what does Teamviewer have that you need, that these more basic and free applications don't? Teamviewer has a nice file management structure, but that capability can be approximated by simply using Dropbox along with these other free apps.
Posted by vice86
Trigon
i like that file transfer between remote/PC is included with free TeamVierwer. The other remote desktop I started using only includes file transfers if you pay a yearly fee.
