Announcements
TeamViewer 14.5 has been released. See the Change Logs here.
Posted by User47
Henagon
View settings when remote monitor is vertical?
The remote station to which I am connecting has a vertical monitor (portrait).  When I use MS remote desktop the window on my end shows up in a horizontal window (landscape).  This was immensely useful.  We recently switched to using Teamviewer. However, when I connect to the same remote computer the remote destktop windows is forced into a vertical (portrait) format. The resulting image is quite tiny or if I use scaling, I have to constanly use the vertical scroll bars.  So my question is: is there some combination of View Settings in the Advanced section of the properties to give me the same behavior as MS remote desktop?
1 Reply
Posted by User47
Henagon
Re: View settings when remote monitor is vertical?
Does anyone from Teamviewer even read this community forum?
